주요 콘텐츠로 건너뛰기
Samsung Propel Screen Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Samsung Propel Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Press down the back and push up to remove back cover.
    • Insert finger into gap at the top left and remove battery.
  2. Samsung Propel Screen Replacement, Motherboard: 2 단계, 이미지 1/1
    • Use a flat-head screwdriver to remove the back lid.
  3. Samsung Propel Screen Replacement: 3 단계, 이미지 1/1
    • Locate the six screws and remove them with a Phillips #00 Screwdriver.
    • Insert the flat-head screwdriver into the crevice.
    • Slide and dislodge the snap-ons that are beneath the crevice.
    • Remove the back frame of the device.
  4. Samsung Propel Screen Replacement: 5 단계, 이미지 1/1
    • Locate and remove the six screws with a Phillips #00 Screwdriver.
    • Separate the black middle frame from the front frame.
    • Be careful not to tear the phone bus.
  5. Samsung Propel Screen Replacement: 6 단계, 이미지 1/1
    • Locate and remove the four screws with a Phillips #00 Screwdriver.
    • Slide the flat-head screwdriver and dislodge the snap-ons beneath the crevice.
    • Be careful not to rip the band.
  6. Samsung Propel Screen Replacement: 8 단계, 이미지 1/1
    • Use your hands to remove both the phone buses from the linkages and remove the motherboard.
  7. Samsung Propel Screen Replacement, Screen: 9 단계, 이미지 1/2 Samsung Propel Screen Replacement, Screen: 9 단계, 이미지 2/2
    • Flip and pull eletric band from input.
    • Remove the screen from the front frame.
결론
Jin
회원 가입일: 04/28/11
101 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-3, Nelson Spring 2011 CSU Los Angeles, Team 1-3, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,735
