주요 콘텐츠로 건너뛰기
Samsung RC512 Cooling Fan/Heat Sink Replacement
필요한 것
  1. Samsung RC512 Cooling Fan/Heat Sink Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside down.
  2. Samsung RC512 Cooling Fan/Heat Sink Replacement: 2 단계, 이미지 1/2 Samsung RC512 Cooling Fan/Heat Sink Replacement: 2 단계, 이미지 2/2
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Cooling Fan/Heat Sink Replacement, Back Panel: 3 단계, 이미지 1/3 Samsung RC512 Cooling Fan/Heat Sink Replacement, Back Panel: 3 단계, 이미지 2/3 Samsung RC512 Cooling Fan/Heat Sink Replacement, Back Panel: 3 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
    • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
    • Carefully remove the back panel..
  4. Samsung RC512 Cooling Fan/Heat Sink Replacement, HDD: 4 단계, 이미지 1/1
    • Carefully lift the HDD up using plastic opening tool.
  5. Samsung RC512 Cooling Fan/Heat Sink Replacement: 5 단계, 이미지 1/1
    • Grab the HDD and connector.
    • Carefully pull the HDD away from the connector.
  6. Samsung RC512 Cooling Fan/Heat Sink Replacement: 6 단계, 이미지 1/1
    • Take out the HDD and leave the connector in the laptop
  7. Samsung RC512 Cooling Fan/Heat Sink Replacement, Optic Drive: 7 단계, 이미지 1/1
    • Remove the 4mm Phillips #0 screw using a Phillips #0 screwdriver.
  8. Samsung RC512 Cooling Fan/Heat Sink Replacement: 8 단계, 이미지 1/3 Samsung RC512 Cooling Fan/Heat Sink Replacement: 8 단계, 이미지 2/3 Samsung RC512 Cooling Fan/Heat Sink Replacement: 8 단계, 이미지 3/3
    • Use the spudger or fingers to gently pull the optical drive out.
    • Slide the optic drive away from the laptop.
  9. Samsung RC512 Cooling Fan/Heat Sink Replacement, Cooling Fan/Heat Sink: 9 단계, 이미지 1/2 Samsung RC512 Cooling Fan/Heat Sink Replacement, Cooling Fan/Heat Sink: 9 단계, 이미지 2/2
    • Remove the eight 5mm Phillips #0 screws using a Phillips #0 driver.
    • Also remove the three 5mm Phillips #0 using a Phillips #0 driver.
  10. Samsung RC512 Cooling Fan/Heat Sink Replacement: 10 단계, 이미지 1/3 Samsung RC512 Cooling Fan/Heat Sink Replacement: 10 단계, 이미지 2/3 Samsung RC512 Cooling Fan/Heat Sink Replacement: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove three bottom dark covers using tweezers.
    • Remove three 10mm Phillips #0 screws using Phillips #0 driver.
  11. Samsung RC512 Cooling Fan/Heat Sink Replacement: 11 단계, 이미지 1/2 Samsung RC512 Cooling Fan/Heat Sink Replacement: 11 단계, 이미지 2/2
    • Insert a plastic opening tool into the back cover and the housing of the body.
    • Use the plastic opening tool to pop open the clamps that hold the casing onto the back cover.
    • Work your way around the all sides to completely take off the back cover.
    • You may use your fingers to help remove the cover.
    • Carefully lift the back cover. Do not use excessive force to lift it. If it feels like it will not pull up, make sure all the screws have been taken out.
  12. Samsung RC512 Cooling Fan/Heat Sink Replacement: 12 단계, 이미지 1/3 Samsung RC512 Cooling Fan/Heat Sink Replacement: 12 단계, 이미지 2/3 Samsung RC512 Cooling Fan/Heat Sink Replacement: 12 단계, 이미지 3/3
    • Remove two 5mm Phillips #8 screw using a phillips #0 screwdriver.
    • Gently pull out the connector from the motherboard.
  13. Samsung RC512 Cooling Fan/Heat Sink Replacement: 13 단계, 이미지 1/2 Samsung RC512 Cooling Fan/Heat Sink Replacement: 13 단계, 이미지 2/2
    • Remove the six 5mm Phillips #0 screw using a Phillips #0 screwdriver.
    • Gently lift the cooling fan and heat sink to take them off.
    • Heat sink might be hot right after the laptop is shutdown.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
jando
회원 가입일: 09/15/16
896 평판
안내서 8개 작성하였습니다
USF Tampa, Team 18-2, Blackwell Fall 2016 USF Tampa, Team 18-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G2
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Thanks for the graphics. But you missed 3 screws under the battery compartment.
Doing all of this really helped... before, my laptop would just turn off randomly. I'm thinking this was because of overheating.
After this, it hasn't shut down yet.
thank you.
gary.crump - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 15
전체 시간: 1,287
