주요 콘텐츠로 건너뛰기
Samsung RC512 Optic Drive Replacement
필요한 것
  1. Samsung RC512 Optic Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside down.
  2. Samsung RC512 Optic Drive Replacement: 2 단계, 이미지 1/2 Samsung RC512 Optic Drive Replacement: 2 단계, 이미지 2/2
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Optic Drive Replacement, Back Panel: 3 단계, 이미지 1/3 Samsung RC512 Optic Drive Replacement, Back Panel: 3 단계, 이미지 2/3 Samsung RC512 Optic Drive Replacement, Back Panel: 3 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
    • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
    • Carefully remove the back panel..
  4. Samsung RC512 Optic Drive Replacement, Optic Drive: 4 단계, 이미지 1/1
    • Remove the 4mm Phillips #0 screw using a Phillips #0 screwdriver.
  5. Samsung RC512 Optic Drive Replacement: 5 단계, 이미지 1/3 Samsung RC512 Optic Drive Replacement: 5 단계, 이미지 2/3 Samsung RC512 Optic Drive Replacement: 5 단계, 이미지 3/3
    • Use the spudger or fingers to gently pull the optical drive out.
    • Slide the optic drive away from the laptop.
결론
jando
회원 가입일: 09/15/16
896 평판
안내서 8개 작성하였습니다
USF Tampa, Team 18-2, Blackwell Fall 2016 USF Tampa, Team 18-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 330
