주요 콘텐츠로 건너뛰기
Samsung RF4287HABP Ice Maker Repair
필요한 것
  1. Samsung RF4287HABP Ice Maker Repair, Samsung RF4287HABP Ice Maker Repair: 1 단계, 이미지 1/1
    • Push the “Energy Saver” button and “Fridge” button for about 8 seconds.
  2. Samsung RF4287HABP Ice Maker Repair: 2 단계, 이미지 1/1
    • After you hear a beep, continue to press the “Energy Saver” button until “Fd” appears.
    • The refrigerator will continue to beep for approximately 20 minutes until the ice maker has defrosted.
    • Unplug the refrigerator before beginning step 3.
  3. Samsung RF4287HABP Ice Maker Repair: 3 단계, 이미지 1/3 Samsung RF4287HABP Ice Maker Repair: 3 단계, 이미지 2/3 Samsung RF4287HABP Ice Maker Repair: 3 단계, 이미지 3/3
    • Take the ice maker tray out of the icebox and place it in the sink to melt the remaining ice off.
  4. Samsung RF4287HABP Ice Maker Repair: 4 단계, 이미지 1/1
    • Attempt to scrape any ice out of the icebox and defrost the remaining ice with a hairdryer or heat gun.
    • Use caution when applying heat. Excessive heat may cause the plastic to warp or melt, which could cause fit issues during installation.
  5. Samsung RF4287HABP Ice Maker Repair: 5 단계, 이미지 1/2 Samsung RF4287HABP Ice Maker Repair: 5 단계, 이미지 2/2
    • Unscrew the 0.05 mm screw on the left side panel inside the icebox with a Phillips #0 screwdriver.
  6. Samsung RF4287HABP Ice Maker Repair: 6 단계, 이미지 1/2 Samsung RF4287HABP Ice Maker Repair: 6 단계, 이미지 2/2
    • Carefully detach the plug connected to the thick white tube located to the left in the back of the icebox.
  7. Samsung RF4287HABP Ice Maker Repair: 7 단계, 이미지 1/2 Samsung RF4287HABP Ice Maker Repair: 7 단계, 이미지 2/2
    • Press the lever down and slide the ice maker forward at the very top of the icebox.
    • If the lever is stuck, it could be from the remaining ice in your ice maker.
  8. Samsung RF4287HABP Ice Maker Repair: 8 단계, 이미지 1/1
    • Take out the ice tray and place it in the sink. Use a hairdryer to defrost the ice tray completely.
    • Reinsert and reconnect all the parts of the icemaker.
  9. Samsung RF4287HABP Ice Maker Repair: 9 단계, 이미지 1/1
    • Plug the refrigerator back into the electrical outlet.
    • Press and hold the restart button located on the top of the ice maker beside the lever.
  10. Samsung RF4287HABP Ice Maker Repair: 10 단계, 이미지 1/1
    • Unplug and plug the refrigerator if you do not hear a sound from the ice maker. Press and hold the restart button again until you hear water draining into the ice maker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Madisyn
회원 가입일: 09/30/21
208 평판
안내서 1개 작성함
University of Memphis, Team 50-11, Willis Fall 2021 University of Memphis, Team 50-11, Willis Fall 2021 회원
UM-WILLIS-F21S50G11
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 26
30일 전: 96
전체 시간: 4,437
