소개
There could be many reasons the Bluetooth module on the device will not connect, such as water damage or electric shock. This guide will show you step by step how to replace a non-functioning Bluetooth Module. In order to start working on your device, you will need to prepare a clean, dry, and flat work space. It is recommended to have a place to store screws during the process.
필요한 것
Use the plastic opening tool to lift and remove the rubber grommet plugs.
Remove the four (9.5mm x 1.6mm) PH1 Phillips screws on the port speaker body.
Remove the Port Panel exposing the subwoofer.
댓글 4개
Nice write up, but where does one obtain a new Bluetooth module for one of these?
Bluetooth module model is WIBT30D. You can google for it. It cost ~30 euro now
You all seem to know your way around these devices. Do you think it's possible to create an 'aux' style connection to allow wired playback? If WiFi and Bluetooth are failing, having the ability to connect to connect via wire would be really good.
