주요 콘텐츠로 건너뛰기
Samsung Radiant 360 R1 Micro USB / Power Port Panel Replacement
필요한 것
  1. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement, Micro USB / Power Port Panel: 1 단계, 이미지 1/1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Use the plastic opening tool to lift and remove the rubber grommet plugs.
  2. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: 2 단계, 이미지 1/1
    • Using a PH1 Philips screwdriver, remove four (9.5mm x 1.6mm) screws from the base plate.
    • Remove base plate by stabilizing speaker and using plastic prying tool to pry the base plate from the speaker.
  3. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: 3 단계, 이미지 1/1
    • Place the speaker on the table with the Touch Pad facing down. This will leave you with the Port Panel exposed.
    • Remove speaker grill by stabilizing speaker on a table and applying pressure to the bottom of the speaker. Slide the speaker grill up and away from the remaining endcap.
  4. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: 4 단계, 이미지 1/1
    • Remove the two exposed (9.5mm x 1.6mm) PH1 Phillips screws on the Port Panel.
    • Remove the Port Panel from the speaker body, exposing the ribbon cables.
  5. Samsung Radiant 360 R1 Micro USB / Power Port Panel  Replacement: 5 단계, 이미지 1/1
    • While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Dutton
회원 가입일: 02/01/17
122 평판
안내서 1개 작성함
UW Tacoma, Team 2-5, Rose Winter 2017 UW Tacoma, Team 2-5, Rose Winter 2017 회원
UWT-ROSE-W17S2G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 928
