소개
This guide will walk you through the process of removing the bottom of the speaker, the outer shell, the subwoofer and accessing the tweeter speaker for removal.
필요한 것
Remove the two 12mm long screws with the Phillips #1 screwdriver.
Unplug white plug connected to the green circuit board.
Remove the six 8mm screws using the Phillips #1 screwdriver.
Remove the six 12mm screws using the Phillips #1 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
