소개
In this guide, we will be replacing the USB module of the speaker, which also houses the button used in pairing the speaker for Wi-Fi capabilities. You will need to remove the bottom cover, unplug the connector from the motherboard to it, and remove it from the speaker assembly.
필요한 것
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
