주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Rant Battery Replacement
  1. Samsung Rant Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Battery Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Carefully remove the battery from the phone.
결론
*New Battery information: Standard Lithium Ion (Li-Ion); Talk time: 5.6 hours max. (336 minutes)
작성자
6다른 기여자 명과 함께
Todd
회원 가입일: 10/18/11
1 평판
안내서 1개를 작성함
James Madison, Team 1-6, Allen Fall 2011 James Madison, Team 1-6, Allen Fall 2011 회원
JMU-ALLEN-F11S1G6
4 회원들
안내서 12개를 작성함
1가이드 댓글
*New batteries need to be charged before use.
*You should charge your battery in an area that is free of moisture, extreme cold or extreme heat.
*Refer to the repair manual (Samsung Rant Device page above) for information on purchasing a battery and battery life.
Denise Cooper - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 32
전체 시간: 1,634
