주요 콘텐츠로 건너뛰기
소개
In some cases, the motherboard of a device may stop working due to installment issues or a short circuit. Either way, we have created a user-friendly guide that will show you how to fix your device
부품
지정된 부품이 없습니다.
  1. Start by removing the back plate and battery of the phone.
    • Start by removing the back plate and battery of the phone.
  2. Using a Phillip’s #00 screwdriver, unscrew the 6 screws located on the back of the device. Using a Phillip’s #00 screwdriver, unscrew the 6 screws located on the back of the device.
    • Using a Phillip’s #00 screwdriver, unscrew the 6 screws located on the back of the device.
  3. Remove the casing from the back of the device. Remove the casing from the back of the device.
    • Remove the casing from the back of the device.
  4. Next, separate the back component from the keyboard and screen, exposing the middle of the phone and keyboard pad. Next, separate the back component from the keyboard and screen, exposing the middle of the phone and keyboard pad.
    • Next, separate the back component from the keyboard and screen, exposing the middle of the phone and keyboard pad.
  5. Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard. Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard. Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard.
    • Last, unscrew the remaining screws and remove the keyboard padding, exposing the motherboard.
결론
Katelynn Lee
회원 가입일: 2011년 10월 18일
1 평판
안내서 1개 작성함
James Madison, Team 1-6, Allen Fall 2011 James Madison, Team 1-6, Allen Fall 2011 회원
JMU-ALLEN-F11S1G6
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Est ce que ce téléphone a une puce ?
Allassane Diawara - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 4,114
