주요 콘텐츠로 건너뛰기
Samsung Rant Rear Case Replacement
필요한 것
  1. Samsung Rant Rear Case Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Rear Case Replacement, Rear Case: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  3. Samsung Rant Rear Case Replacement: 3 단계, 이미지 1/1
    • Gently separate the rear case from the front case.
결론
Denise Cooper
회원 가입일: 10/18/11
31 평판
안내서 3개 작성하였습니다
James Madison, Team 1-6, Allen Fall 2011 James Madison, Team 1-6, Allen Fall 2011 회원
JMU-ALLEN-F11S1G6
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 1,142
