주요 콘텐츠로 건너뛰기
Samsung Refrigerator Light (Refrigerator Compartment) Replacement
필요한 것
  1. Samsung Refrigerator Light (Refrigerator Compartment) Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Light (Refrigerator Compartment) Replacement, Open the refrigerator doors: 2 단계, 이미지 2개 중 1개 Samsung Refrigerator Light (Refrigerator Compartment) Replacement, Open the refrigerator doors: 2 단계, 이미지 2개 중 2개
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Light (Refrigerator Compartment) Replacement, Remove the light cover: 3 단계, 이미지 3개 중 1개 Samsung Refrigerator Light (Refrigerator Compartment) Replacement, Remove the light cover: 3 단계, 이미지 3개 중 2개 Samsung Refrigerator Light (Refrigerator Compartment) Replacement, Remove the light cover: 3 단계, 이미지 3개 중 3개
    • Plastic clips hold the light cover in place.
    • Use a spudger to pry along the back edge of the light cover.
    • You can also use a flathead screwdriver, but be careful not to let the screwdriver slip, or you'll scratch your refrigerator surface.
    • Remove the light cover.
  4. Samsung Refrigerator Light (Refrigerator Compartment) Replacement, Remove the light panel: 4 단계, 이미지 1개 중 1개
    • Remove the screws securing the light panel.
  5. Samsung Refrigerator Light (Refrigerator Compartment) Replacement: 5 단계, 이미지 3개 중 1개 Samsung Refrigerator Light (Refrigerator Compartment) Replacement: 5 단계, 이미지 3개 중 2개 Samsung Refrigerator Light (Refrigerator Compartment) Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger or a flathead screwdriver to pry and loosen the light panel.
    • Don't try to remove the light panel yet, as it's connected to the refrigerator with a cable.
  6. Samsung Refrigerator Light (Refrigerator Compartment) Replacement: 6 단계, 이미지 2개 중 1개 Samsung Refrigerator Light (Refrigerator Compartment) Replacement: 6 단계, 이미지 2개 중 2개
    • Use your fingers to unplug the light's wire connector.
  7. Samsung Refrigerator Light (Refrigerator Compartment) Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the refrigerator light.
결론
Repair didn’t go as planned? Ask our Answers Community for help.
작성자
1다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
Team Vulcan Team Vulcan 회원
Staff
6 회원들
안내서 212개를 작성함
2가이드 댓글
I have a Samsung Refrigerator not sure what its called but it between the french doors a plastic stripe that is on the left side of door
Donna - 답글
I believe that the strip between the doors that folds back when the doors are opened is called a mullion strip. It allows the doors to be sealed when closed, but moves out of the way when the doors are opened.
Bill Gilbert -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 71
전체 시간: 1,177
