주요 콘텐츠로 건너뛰기
Samsung Refrigerator Wi-Fi Card Replacement
필요한 것
  1. Samsung Refrigerator Wi-Fi Card Replacement, Unplug your refrigerator: 1 단계, 이미지 1개 중 1개
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Wi-Fi Card Replacement, Remove the hinge cover: 2 단계, 이미지 1개 중 1개
    • Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
  3. Samsung Refrigerator Wi-Fi Card Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung Refrigerator Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 1개 Samsung Refrigerator Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 2개
    • Use your fingers to release the wire connectors under the hinge cover.
    • Disconnect the wiring so you can remove the hinge cover.
  5. Samsung Refrigerator Wi-Fi Card Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the hinge cover.
  6. Samsung Refrigerator Wi-Fi Card Replacement, Remove the Wi-Fi card: 6 단계, 이미지 3개 중 1개 Samsung Refrigerator Wi-Fi Card Replacement, Remove the Wi-Fi card: 6 단계, 이미지 3개 중 2개 Samsung Refrigerator Wi-Fi Card Replacement, Remove the Wi-Fi card: 6 단계, 이미지 3개 중 3개
    • The Wi-Fi card is attached to the hinge cover.
    • Use your fingers to squeeze and slide the Wi-Fi cable connector out of its socket.
  7. Samsung Refrigerator Wi-Fi Card Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the screws securing the Wi-Fi card to the hinge cover.
  8. Samsung Refrigerator Wi-Fi Card Replacement: 8 단계, 이미지 1개 중 1개
    • Lift and remove the Wi-Fi card.
결론
Repair didn’t go as planned? Ask our Answers Community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
Team Vulcan Team Vulcan 회원
Staff
6 회원들
안내서 212개를 작성함
13가이드 댓글
Hi nico, can you share pictures for the cables of this wifi module? pin colors and order please in both sides ? Thank you.
Danilo Freitas - 답글
Thank-you for this Detailed replacement step. I do have one question: I am currently having an issue with my Refrigerator dropping its WIFI connection when the refrigerator door is opened or closed (same model). When it drops it goes back into AP mode and constantly chimes. If I wanted to just 'disable' WIFI all together on this refrigerator, could I just unplug the WIFI cable from the card and leave it unplugged? Would the refrigerator still function normal without this card and stop chiming to setup WIFI?
Brad_2024 - 답글
I have this model RS27T5561SR the WiFi is not working at all. Where can I purchase the WiFi chip from? Thanks
Everette Egun - 답글
I have a Samsung Refrigerator w/ Family Hub model RF265BEAESR and the wi-fi adaptor is not working and is not located as shown above...do you know where it is located?
Stephen Landry - 답글
Hi Nico, can you possibly answer Brad's question? I want to unplug my wifi board too! I have disabled the wifi through the control panel but my EMF meter shows that it is constantly sending out pulses that register quite high and hot on my meter.
Ron Larkin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 38
지난 30일: 163
전체 시간: 1,827
