주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Rogue Keyboard Replacement
필요한 것
  1. Samsung Rogue Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Keyboard Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Samsung Rogue Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Samsung Rogue Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Keyboard Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
    • Remove the eight 1.7mm Philips screws above the keyboard.
  10. Samsung Rogue Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Carefully remove keyboard holder from the slider mechanisms underneath.
  11. Samsung Rogue Keyboard Replacement: 11 단계, 이미지 2개 중 1개 Samsung Rogue Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    • Turn keyboard holder over and allow the keyboard to simply fall out into your hand.
결론
작성자
5다른 기여자 명과 함께
Viktoria Mikoultchik
회원 가입일: 04/15/12
25 평판
안내서 7개를 작성함
Cal Poly, Team 7-32, Maness Spring 2012 Cal Poly, Team 7-32, Maness Spring 2012 회원
CPSU-MANESS-S12S7G32
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 59
전체 시간: 525
