주요 콘텐츠로 건너뛰기
Samsung S630 LCD Display Replacement
필요한 것
  1. Samsung S630 LCD Display Replacement, LCD Display: 1 단계, 이미지 1/1
    • Here is my Samsung S630. Nice little camera with just one flaw. The LCD display was broken.
  2. Samsung S630 LCD Display Replacement: 2 단계, 이미지 1/3 Samsung S630 LCD Display Replacement: 2 단계, 이미지 2/3 Samsung S630 LCD Display Replacement: 2 단계, 이미지 3/3
    • Remove the two screws on the left side.
    • Remove the two on the right side.
    • Remove the four screws on the bottom. All eight screws are the same, so no need to ensure proper position when reassembling.
  3. Samsung S630 LCD Display Replacement: 3 단계, 이미지 1/1
    • Open the battery cover and split the housing carefully. Start at the battery compartment and work your way around it. You can use an opening tool or your fingernails. Also make sure to open the USB port cover.
  4. Samsung S630 LCD Display Replacement: 4 단계, 이미지 1/3 Samsung S630 LCD Display Replacement: 4 단계, 이미지 2/3 Samsung S630 LCD Display Replacement: 4 단계, 이미지 3/3
    • You now look directly onto the LCD.
    • Gently move the LCD out of the frame and fold it toward the bottom of the camera. Do not try to remove it. It is still attached.
    • Remove the four screws that hold the frame to the logic board.
  5. Samsung S630 LCD Display Replacement: 5 단계, 이미지 1/2 Samsung S630 LCD Display Replacement: 5 단계, 이미지 2/2
    • This particular camera has some Kapton tape holding the cable to the logic board. Gently remove it from the board only.
    • Open the locking tab on the PCB connector and remove the cable. This will separate the LCD from the board.
    • This is what the logic board looks like without the frame and the LCD.
결론
다른 3명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
782,169 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 537개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 20
전체 시간: 2,626
