주요 콘텐츠로 건너뛰기
Samsung S730 lcd screen replacement
필요한 것
  1. Samsung S730 lcd screen replacement, LCD: 1 단계, 이미지 1/3 Samsung S730 lcd screen replacement, LCD: 1 단계, 이미지 2/3 Samsung S730 lcd screen replacement, LCD: 1 단계, 이미지 3/3
    • Remove the batteries, memory card, and wrist strap if so equipped.
    • Remove the four screws on the bottom.
    • Remove the two screws on the right hand side
  2. Samsung S730 lcd screen replacement: 2 단계, 이미지 1/3 Samsung S730 lcd screen replacement: 2 단계, 이미지 2/3 Samsung S730 lcd screen replacement: 2 단계, 이미지 3/3
    • Remove the two screws from the left hand side
    • The screws are identical in length. No reason to keep them separate
    • Split the case from the battery compartment down. You can use an opening tool or your fingernails to accomplish that.
  3. Samsung S730 lcd screen replacement: 3 단계, 이미지 1/2 Samsung S730 lcd screen replacement: 3 단계, 이미지 2/2
    • With the case split, you can see the LCD in its holder. The LCD is simply laid into the holder.
    • Gently remove the LCD from the holder and just flip it to the side. Do not remove it yet. You will have to loosen the clip on the connector. Use your fingernails to move it in the opposite direction from the LCD, this will open it up. Remove the LCD and replace with new one.
결론
다른 2명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
782,174 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 537개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 1,318
