소개
This guide will take you through the steps of removing parts of your device to reach and replace the lens
필요한 것
Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Brilliantly explained. Makes it look so easy… even a fool such as I could follow the instructions.
the guide is actually beautiful im just upset that mine got corroded from battery leakage and rusted the capacitors next to the charging port and caused it to fall off :c
