주요 콘텐츠로 건너뛰기
Samsung S760 Front and Back Case Replacement Guide
필요한 것
  1. Samsung S760 Front and Back Case Replacement Guide, Battery: 1 단계, 이미지 1/3 Samsung S760 Front and Back Case Replacement Guide, Battery: 1 단계, 이미지 2/3 Samsung S760 Front and Back Case Replacement Guide, Battery: 1 단계, 이미지 3/3
    • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
  2. Samsung S760 Front and Back Case Replacement Guide: 2 단계, 이미지 1/2 Samsung S760 Front and Back Case Replacement Guide: 2 단계, 이미지 2/2
    • Tip the camera as to gently slide the batteries out of the camera.
  3. Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: 3 단계, 이미지 1/3 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: 3 단계, 이미지 2/3 Samsung S760 Front and Back Case Replacement Guide, Front and Back Case: 3 단계, 이미지 3/3
    • All screws in this camera are removed using the Phillip Screwdriver #000 bit. Also, all dimensions included refer to screw lengths.
    • Locate and remove the six 4mm screws on the sides of the camera.
  4. Samsung S760 Front and Back Case Replacement Guide: 4 단계, 이미지 1/2 Samsung S760 Front and Back Case Replacement Guide: 4 단계, 이미지 2/2
    • Use the plastic opening tool to pry open the back case, following alongside the edge of the case if need be.
  5. Samsung S760 Front and Back Case Replacement Guide: 5 단계, 이미지 1/1
    • Once the back case is removed, use the plastic opening tool to gently pry off the front case.
결론
This will be used as a prerequisite to other guides. To reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
David Sepulveda
회원 가입일: 03/06/17
425 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S8-G1, Catania Spring 2017 UMass Dartmouth, Team S8-G1, Catania Spring 2017 회원
UMASSD-CATANIA-S17S8G1
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 252
