소개
The LCD screen can be cracked or water damaged
필요한 것
Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
Locate and remove the six 4mm screws on the sides of the camera, using the Phillip Screwdriver #000 bit.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
