주요 콘텐츠로 건너뛰기
Samsung S85 Lens Replacement
필요한 것
  1. Samsung S85 Lens Replacement, Lens Unit: 1 단계, 이미지 1/3 Samsung S85 Lens Replacement, Lens Unit: 1 단계, 이미지 2/3 Samsung S85 Lens Replacement, Lens Unit: 1 단계, 이미지 3/3
    • Remove 8 screws securing outside shell. Screw locations can be found in pictures
    • Place Screws on magnetic surface or location where they will not roll away
  2. Samsung S85 Lens Replacement: 2 단계, 이미지 1/3 Samsung S85 Lens Replacement: 2 단계, 이미지 2/3 Samsung S85 Lens Replacement: 2 단계, 이미지 3/3
    • Rotate camera such that battery door is facing upwards
    • Squeeze area where fingers are located with thumb and remove outside shell.
  3. Samsung S85 Lens Replacement: 3 단계, 이미지 1/3 Samsung S85 Lens Replacement: 3 단계, 이미지 2/3 Samsung S85 Lens Replacement: 3 단계, 이미지 3/3
    • After removing you see a few wires and a screen placed on top of the circuit board looking similar to the first picture. If you don't, you might have not taken apart the wrong camera, yikes!
    • The second picture outlines where you can locate all the surface screws. Note that these will not be the only screws needed to be taken off to remove the circuit board.
    • As shown in the third picture be careful when removing the screw hidden behind the circuit.
  4. Samsung S85 Lens Replacement: 4 단계, 이미지 1/2 Samsung S85 Lens Replacement: 4 단계, 이미지 2/2
    • After removing two screws holding screen down flip screen over gently.
    • Remove three screws underneath screen as shown in pictures
  5. Samsung S85 Lens Replacement: 5 단계, 이미지 1/2 Samsung S85 Lens Replacement: 5 단계, 이미지 2/2
    • Using tweezers, pinch white portion of circuit as shown in picture and twist upwards. This should loosen the circuit itself.
    • Using tweezers, gently remove circuit from white plastic attachment.
    • Flip screen over and remove top most circuit closest to power button using same method.
  6. Samsung S85 Lens Replacement: 6 단계, 이미지 1/3 Samsung S85 Lens Replacement: 6 단계, 이미지 2/3 Samsung S85 Lens Replacement: 6 단계, 이미지 3/3
    • Be very cautious when using a soldering iron for the next couple steps (they are on average 300 F)
    • Using a soldering iron, remove solder from each circled location in each image to remove corresponding wires
  7. Samsung S85 Lens Replacement: 7 단계, 이미지 1/2 Samsung S85 Lens Replacement: 7 단계, 이미지 2/2
    • Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
    • Repeat step two to three times until board feels flexible to bend
  8. Samsung S85 Lens Replacement: 8 단계, 이미지 1/1
    • Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
  9. Samsung S85 Lens Replacement: 9 단계, 이미지 1/3 Samsung S85 Lens Replacement: 9 단계, 이미지 2/3 Samsung S85 Lens Replacement: 9 단계, 이미지 3/3
    • Remove three interior screws as noted in the first picture.
    • Remove screwed attached to orange circuit ribbon as shown in second picture.
    • Remove third screw attached to orange circuit ribbon as shown in third picture.
  10. Samsung S85 Lens Replacement: 10 단계, 이미지 1/3 Samsung S85 Lens Replacement: 10 단계, 이미지 2/3 Samsung S85 Lens Replacement: 10 단계, 이미지 3/3
    • Using screwdriver, remove silver metal piece located in center of camera.
    • Using tweezers, gently remove orange circuit from lens. This step is tricky as the orange circuit is very securely placed in the lens.
    • After the removal of the silver piece and orange circuit remove black circle from center of camera. This is the lens
    • Gently remove top portion of lens as shown in the third picture.
  11. Samsung S85 Lens Replacement: 11 단계, 이미지 1/2 Samsung S85 Lens Replacement: 11 단계, 이미지 2/2
    • Remove two screws attached to internal part of lens using screwdriver
    • Using tweezers to remove thin black layer to reveal lens.
결론
To reassemble your device we have provided pictures working backwards.
다른 한 분이 해당 안내서를 완성하였습니다.
Avinash Salgam
회원 가입일: 02/16/14
597 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 1,114
