주요 콘텐츠로 건너뛰기
Samsung S85 Rubber Door Replacement
필요한 것
  1. Samsung S85 Rubber Door Replacement, Rubber Door: 1 단계, 이미지 3개 중 1개 Samsung S85 Rubber Door Replacement, Rubber Door: 1 단계, 이미지 3개 중 2개 Samsung S85 Rubber Door Replacement, Rubber Door: 1 단계, 이미지 3개 중 3개
    • Remove 4 screws from bottom of camera
    • Remove 2 screws from side of camera
    • Place Screws on magnetic surface or location where they will not roll away
  2. Samsung S85 Rubber Door Replacement: 2 단계, 이미지 1개 중 1개
    • Squeeze area noted by blue square and pull outside shell apart from remaining camera.
  3. Samsung S85 Rubber Door Replacement: 3 단계, 이미지 2개 중 1개 Samsung S85 Rubber Door Replacement: 3 단계, 이미지 2개 중 2개
    • Remove 6 screws identified by red circles
    • Remove 3 screws identified by orange circles
  4. Samsung S85 Rubber Door Replacement: 4 단계, 이미지 2개 중 1개 Samsung S85 Rubber Door Replacement: 4 단계, 이미지 2개 중 2개
    • Gently remove orange circuit ribbon identified by red square
    • Gently remove narrow orange circuit ribbon identified by blue square
  5. Samsung S85 Rubber Door Replacement: 5 단계, 이미지 3개 중 1개 Samsung S85 Rubber Door Replacement: 5 단계, 이미지 3개 중 2개 Samsung S85 Rubber Door Replacement: 5 단계, 이미지 3개 중 3개
    • Be very cautious when using a soldering iron (they are on average 300 F)
    • Using a soldering iron, remove solder from wire identified by red circle
    • Using a soldering iron, remove solder from black and red wire identified by orange circle
    • Using a soldering iron, remove solder from wire identified by yellow circle
  6. Samsung S85 Rubber Door Replacement: 6 단계, 이미지 3개 중 1개 Samsung S85 Rubber Door Replacement: 6 단계, 이미지 3개 중 2개 Samsung S85 Rubber Door Replacement: 6 단계, 이미지 3개 중 3개
    • Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
    • Repeat step two to three times until board feels flexible to bend
    • Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
  7. Samsung S85 Rubber Door Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove black rubber door located on side of camera closest to lens using tweezers.
    • Be careful not to bend or tear the rubber when pulling out with tweezers as it may become difficult to put back in
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Avinash Salgam
회원 가입일: 02/16/14
597 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 393
