이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove 4 screws from bottom of camera
Remove 2 screws from side of camera
Squeeze area noted by blue square and pull outside shell apart from remaining camera.
Remove 6 screws identified by red circles
Remove 3 screws identified by orange circles
Gently remove orange circuit ribbon identified by red square
Gently remove narrow orange circuit ribbon identified by blue square
Using a soldering iron, remove solder from wire identified by red circle
Using a soldering iron, remove solder from black and red wire identified by orange circle
Using a soldering iron, remove solder from wire identified by yellow circle
Using soldering iron, melt away solder and warm up metal located at top of circuit board as shown in picture
Repeat step two to three times until board feels flexible to bend
Slowly bend circuit board upwards (towards power button) until at 90 degree angle with remaining part of camera.
Remove black rubber door located on side of camera closest to lens using tweezers.
다른 한 분이 해당 안내서를 완성하였습니다.
