소개
If your Samsung S860 is not working properly or turning on, the camera may need a new battery. This guide will provide assistance on how to replace the batteries in the camera.
Working batteries provide power for the camera. If the camera will not turn on or the camera is not functioning to its full capacity, a new battery may be required.
Battery replacement is fairly simple. The process requires opening the battery compartment and replacing old batteries with new ones.
Note: Apply firm pressure when sliding open the battery compartment.
With the camera facing LCD side up, slide the battery compartment lid to the right.
Remove the old batteries.
다른 한 분이 해당 안내서를 완성하였습니다.
