주요 콘텐츠로 건너뛰기
Samsung SC MX-20 Lens Replacement
필요한 것
  1. Samsung SC MX-20 Lens  Replacement, Lens: 1 단계, 이미지 1/3 Samsung SC MX-20 Lens  Replacement, Lens: 1 단계, 이미지 2/3 Samsung SC MX-20 Lens  Replacement, Lens: 1 단계, 이미지 3/3
    • Unscrew the eight 4mm screws using the Phillips #000 screwdriver.
  2. Samsung SC MX-20 Lens  Replacement: 2 단계, 이미지 1/3 Samsung SC MX-20 Lens  Replacement: 2 단계, 이미지 2/3 Samsung SC MX-20 Lens  Replacement: 2 단계, 이미지 3/3
    • Unplug the cord connecting the LCD section of the device.
    • Remove the left face of the device.
    • Remove the top face by removing the three 4mm screws using a Phillips #000 screwdriver.
  3. Samsung SC MX-20 Lens  Replacement: 3 단계, 이미지 1/3 Samsung SC MX-20 Lens  Replacement: 3 단계, 이미지 2/3 Samsung SC MX-20 Lens  Replacement: 3 단계, 이미지 3/3
    • After removing the body of the device, unscrew the two 3.5mm Phillips #000 screws holding the battery compartment in place.
    • Remove the battery compartment.
  4. Samsung SC MX-20 Lens  Replacement: 4 단계, 이미지 1/3 Samsung SC MX-20 Lens  Replacement: 4 단계, 이미지 2/3 Samsung SC MX-20 Lens  Replacement: 4 단계, 이미지 3/3
    • Remove the lens assembly from the device.
  5. Samsung SC MX-20 Lens  Replacement: 5 단계, 이미지 1/3 Samsung SC MX-20 Lens  Replacement: 5 단계, 이미지 2/3 Samsung SC MX-20 Lens  Replacement: 5 단계, 이미지 3/3
    • Remove the three 3.5mm Phillips #000 screws on the metal part from the lens component.
    • Remove the motherboard from the lens.
    • Remove the lens from the lens assembly.
결론
Austin Williams
회원 가입일: 09/24/19
171 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 169
