도구
도구는 필요하지 않습니다.
부품
부품은 필요하지 않습니다.
  1. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
    • Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
  2. Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
    • Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Lift battery away from phone case.
    • Lift battery away from phone case.
    • The battery is now removed from the device. Congratulations.
  5. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
    • Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
  6. When unscrewed, pull the antenna straight up and out.
    • When unscrewed, pull the antenna straight up and out.
  7. Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional). The antenna and its guide tube are now removed from the phone. Congratulations.
    • Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional).
    • The antenna and its guide tube are now removed from the phone. Congratulations.
결론
Brett Tomashitis
회원 가입일: 2012년 03월 09일
36 평판
안내서 5개 작성하였습니다
Clemson, Team 2-6, Benson Spring 2012 Clemson, Team 2-6, Benson Spring 2012 회원
CLEM-BENSON-S12S2G6
2 회원들
안내서 10개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 625
