부품
부품은 필요하지 않습니다.
  1. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb. Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
    • Turn Samsung SCH3500 around so that the back is facing you. Depress locking tab on the back of the phone with a finger or thumb.
  2. Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
    • Slide battery toward bottom of the phone, ~1/4 inch, to clear the hooks that keep it secured to the back of the phone.
  3. Lift battery away from phone case.
    • Lift battery away from phone case.
    • The battery is now removed from the device. Congratulations.
  4. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone. Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
    • Grasp antenna firmly and rotate counterclockwise to unscrew it from the phone.
  5. When unscrewed, pull the antenna straight up and out.
    • When unscrewed, pull the antenna straight up and out.
  6. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional). The antenna and its guide tube are now removed from the phone. Congratulations.
    • Pull guide tube free from its retaining ring and slide it out the top, like the antenna (optional).
    • The antenna and its guide tube are now removed from the phone. Congratulations.
  8. Remove the four screws using a T6 Torx screwdriver.
    • Remove the four screws using a T6 Torx screwdriver.
  9. Work from the bottom of the phone, separating the two halves of the case. Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
    • Work from the bottom of the phone, separating the two halves of the case.
    • Note: Take care to keep the logic board with the front case half. Part of the logic board is exposed to the sticker under the battery on the rear case half.
  10. Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Angle the rear case half away from the top of the front case half, pivoting the hooks out of their clasps.
    • Caution: Do not fully separate the halves. There is an antenna ribbon connected to the logic board from the back cover.
  11. Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end. The Back Cover is now removed. Congratulations. The Back Cover is now removed. Congratulations.
    • Disconnect the antenna ribbon cable from the logic board at the Zero Insertion Force (ZIF) connector. The brown portion of the connector lifts up to release the cable end.
    • The Back Cover is now removed. Congratulations.
  12. Remove the connector for the earpiece speaker, located on the upper end of the logic board.
    • Remove the connector for the earpiece speaker, located on the upper end of the logic board.
  13. Turn the front cover over, gently prying the logic board away from the front cover. It will remain attached by two wires from the front of the board.
    • Turn the front cover over, gently prying the logic board away from the front cover. It will remain attached by two wires from the front of the board.
  14. Work the microphone out of its socket on the front cover; it will remain attached to the logic board, its wires are soldered. The logic board is now removed from the phone. Congratulations.
    • Work the microphone out of its socket on the front cover; it will remain attached to the logic board, its wires are soldered.
    • The logic board is now removed from the phone. Congratulations.
결론
Brett Tomashitis
회원 가입일: 2012년 03월 09일
36 평판
안내서 5개 작성하였습니다
Clemson, Team 2-6, Benson Spring 2012 Clemson, Team 2-6, Benson Spring 2012 회원
CLEM-BENSON-S12S2G6
2 회원들
안내서 10개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 714
