주요 콘텐츠로 건너뛰기
Samsung SCH-8500 Front Cover Replacement
필요한 것
  1. Samsung SCH-8500 Front Cover Replacement, Front Cover: 1 단계, 이미지 1/1
    • Use a Philips #0 screwdriver to remove the two screws below the screen.
  2. Samsung SCH-8500 Front Cover Replacement: 2 단계, 이미지 1/3 Samsung SCH-8500 Front Cover Replacement: 2 단계, 이미지 2/3 Samsung SCH-8500 Front Cover Replacement: 2 단계, 이미지 3/3
    • Using the spudger, separate the black speaker cover from the top part of the phone.
    • Gently remove the black speaker cover completely.
    • Remove the two screws, approximately 10 mm in length, behind the black speaker cover with the screwdriver.
  3. Samsung SCH-8500 Front Cover Replacement: 3 단계, 이미지 1/2 Samsung SCH-8500 Front Cover Replacement: 3 단계, 이미지 2/2
    • Once the two screws are taken out, use the spudger to remove the front cover of the phone.
결론
Ashley
회원 가입일: 10/22/12
19 평판
안내서 2개 작성하였습니다
Clemson, Team 14-6, Benson Fall 2012 Clemson, Team 14-6, Benson Fall 2012 회원
CLEM-BENSON-F12S14G6
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 336
