이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
With the phone upright and folded shut, locate the two silver tabs at the top of the screen.
Using one hand, pinch the two tabs inward, and use your other hand to slide the front cover of the screen off of the phone.
Using the T6 Torx screwdriver, remove each of the 4mm screws located in the corners of the phone.
Locate the tabs on either side of the phone. Pull the outer case away from each tab with the plastic opening tool.
Hold the phone upside-down.
Two plastic tabs are located under the lip of your phone. Use a plastic opening tool to pop the outer case away from the tabs.
Pry the speakers from the casing, which are attached with only glue.
Pry the board (entire insides) from the casing using the pry tool.
Peel the screen from the rest of the board using your fingers. Be careful not to break anything.
Lastly, peel the white paper up and away from the screen to reveal the screen's electrical connection.
Remove the screen's electrical tab, disconnecting the entire screen from the phone.
