주요 콘텐츠로 건너뛰기
Samsung SCH-A670 Screen Casing Replacement
필요한 것
  1. Samsung SCH-A670 Screen Casing Replacement, Battery Cover: 1 단계, 이미지 1/1
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Screen Casing Replacement, Battery: 2 단계, 이미지 1/1
    • Remove the battery.
  3. Samsung SCH-A670 Screen Casing Replacement, Logic Board: 3 단계, 이미지 1/1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Screen Casing Replacement: 4 단계, 이미지 1/1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Screen Casing Replacement: 5 단계, 이미지 1/1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Screen Casing Replacement: 6 단계, 이미지 1/2 Samsung SCH-A670 Screen Casing Replacement: 6 단계, 이미지 2/2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Screen Casing Replacement: 7 단계, 이미지 1/1
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Screen Casing Replacement: 8 단계, 이미지 1/1
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Screen Casing Replacement, Keypad: 9 단계, 이미지 1/1
    • Once the logic board has been removed, peel the keypad up.
  10. Samsung SCH-A670 Screen Casing Replacement, Keypad Housing: 10 단계, 이미지 1/2 Samsung SCH-A670 Screen Casing Replacement, Keypad Housing: 10 단계, 이미지 2/2
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  11. Samsung SCH-A670 Screen Casing Replacement, Screen Casing: 11 단계, 이미지 1/1
    • Remove screws with #0 Phillips screwdriver.
  12. Samsung SCH-A670 Screen Casing Replacement: 12 단계, 이미지 1/1
    • Carefully pry apart the casing with the spudger tool.
결론
Nathan Brink
회원 가입일: 04/11/10
19 평판
안내서 7개 작성하였습니다
Cal Poly, Team 34-59, Forte Spring 2010 Cal Poly, Team 34-59, Forte Spring 2010 회원
CPSU-FORTE-S10S34G59
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,922
