소개
The screen may become broken over time. This guide will assist in the replacement of the screen.
부품
No parts specified.
  1. Slide the latch on the back of the phone up.
    • Slide the latch on the back of the phone up.
  2. Remove the battery.
    • Remove the battery.
  3. After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. With a #0 Phillips screwdriver remove the screw which you just uncovered.
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  7. Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open. Then disconnect the small power connector near the top of the phone.
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  8. Gently pry up the ribbon-type connector with the spudger.
    • Gently pry up the ribbon-type connector with the spudger.
  9. Carefully pry the logic board from the case with the spudger.
    • Carefully pry the logic board from the case with the spudger.
  10. Once the logic board has been removed, peel the keypad up.
    • Once the logic board has been removed, peel the keypad up.
  11. When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing. When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  12. Remove screws with #0 Phillips screwdriver.
    • Remove screws with #0 Phillips screwdriver.
  13. Carefully pry apart the casing with the spudger tool.
    • Carefully pry apart the casing with the spudger tool.
  14. Use the spudger to carefully pry off the speaker.
    • Use the spudger to carefully pry off the speaker.
  15. Carefully pry off the ringer with the spudger.
    • Carefully pry off the ringer with the spudger.
  16. Carefully pry off the screen with the spudger.
    • Carefully pry off the screen with the spudger.
결론
Nathan Brink
회원 가입일: 2010년 04월 11일
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 34-59, Forte Spring 2010 Cal Poly, Team 34-59, Forte Spring 2010 회원
CPSU-FORTE-S10S34G59
4 회원들
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 3,238
