주요 콘텐츠로 건너뛰기
Samsung SCH-A950 Battery Replacement
  1. Samsung SCH-A950 Battery Replacement, Battery: 1 단계, 이미지 1/2 Samsung SCH-A950 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
결론
Alan Cook
회원 가입일: 01/13/10
44 평판
안내서 3개 작성하였습니다
Cal Poly, Team 11-5, Forte Winter 2010 Cal Poly, Team 11-5, Forte Winter 2010 회원
CPSU-FORTE-W10S11G5
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
What, no glue, 100 microscopic screws, or tiny ribbon cables to remove in the process? No ant sized rubber gaskets to lose? No handling of sensitive tiny components or risk of getting your finger oils on them and reducing functionality? Clearly this is some sort of genius that modern technology cannot attain!
domarius - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 2,224
