이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will teach you how to remove your Samsung ACH-A950's keyboard.
필요한 것
Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
Using a plastic opening tool, disconnect the display cable from the motherboard.
Once the logic board has been removed, the keyboard is exposed and can be removed by simply lifting the keyboard out of the phone housing.
The keyboard can be replaced if needed.
거의 끝나갑니다!
결론
