주요 콘텐츠로 건너뛰기
Samsung SCH-A950 Speakers Replacement
필요한 것
  1. Samsung SCH-A950 Speakers Replacement, Battery: 1 단계, 이미지 1/2 Samsung SCH-A950 Speakers Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  2. Samsung SCH-A950 Speakers Replacement, Volume and Camera Buttons: 2 단계, 이미지 1/1
    • Remove the four Phillips #00 screws underneath the battery.
  3. Samsung SCH-A950 Speakers Replacement: 3 단계, 이미지 1/2 Samsung SCH-A950 Speakers Replacement: 3 단계, 이미지 2/2
    • Pull open the earphone tab and the Trans Flash tab using your fingers.
  4. Samsung SCH-A950 Speakers Replacement: 4 단계, 이미지 1/1
    • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Slide the casing slightly forward towards the top of the phone to remove.
  5. Samsung SCH-A950 Speakers Replacement: 5 단계, 이미지 1/3 Samsung SCH-A950 Speakers Replacement: 5 단계, 이미지 2/3 Samsung SCH-A950 Speakers Replacement: 5 단계, 이미지 3/3
    • Using tweezers or your fingers, lift off buttons from logic board.
    • The buttons can be replaced if needed.
  6. Samsung SCH-A950 Speakers Replacement, Speakers: 6 단계, 이미지 1/2 Samsung SCH-A950 Speakers Replacement, Speakers: 6 단계, 이미지 2/2
    • Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
    • Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
  7. Samsung SCH-A950 Speakers Replacement: 7 단계, 이미지 1/1
    • Using the tweezers, grasp the plastic connector that connects the speaker to the logic board and pull the connector off of the logic board.
  8. Samsung SCH-A950 Speakers Replacement: 8 단계, 이미지 1/1
    • Push the speaker out of the phone using the spudger.
  9. Samsung SCH-A950 Speakers Replacement: 9 단계, 이미지 1/1
    • Remove the speaker from the decorative housing by pulling on the wires.
    • The speaker can be replaced if needed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ashley Parry
회원 가입일: 01/13/10
20 평판
안내서 1개 작성함
Cal Poly, Team 11-5, Forte Winter 2010 Cal Poly, Team 11-5, Forte Winter 2010 회원
CPSU-FORTE-W10S11G5
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,754
