주요 콘텐츠로 건너뛰기
Samsung SCH-U340 Lower Casing Replacement
필요한 것
  1. Samsung SCH-U340 Lower Casing Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Lower Casing Replacement: 2 단계, 이미지 1/1
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Lower Casing Replacement: 3 단계, 이미지 1/1
    • Set the battery aside.
  4. Samsung SCH-U340 Lower Casing Replacement, Lower Casing: 4 단계, 이미지 1/1
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Lower Casing Replacement: 5 단계, 이미지 1/2 Samsung SCH-U340 Lower Casing Replacement: 5 단계, 이미지 2/2
    • Use a spudger to pry the back assembly off of the device.
결론
Anish Sambamurthy
회원 가입일: 02/11/10
31 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-21, Maness Winter 2010 Cal Poly, Team 3-21, Maness Winter 2010 회원
CPSU-MANESS-W10S3G21
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,605
