소개
This guide will cover the removal of the Samsung SCH-U340 top casing.
부품
부품은 필요하지 않습니다.
  1. Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
    • Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
  2. Pull battery up from indent at the bottom and slide it out.
    • Pull battery up from indent at the bottom and slide it out.
  3. Set the battery aside.
    • Set the battery aside.
  4. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs. First remove the plastic plugs covering the screws with a spudger.
    • The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs. First remove the plastic plugs covering the screws with a spudger.
  6. Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver. They will need to be pried out after unscrewing them due to their size. Take care not to lose the screws as they are small and have a tendency to roll.
    • Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver. They will need to be pried out after unscrewing them due to their size. Take care not to lose the screws as they are small and have a tendency to roll.
  7. The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
    • The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
      • To begin removing the outer cover start by prying the large tab up with a flat object.
  8. Continue to pry each tab up, taking care not to break the tabs.
    • Continue to pry each tab up, taking care not to break the tabs.
    • If disaster strikes and a tab is broken, the outer casing can still be put back on assuming the majority of the tabs are still intact.
  9. After the last tab is removed, tug gently on the outer casing to remove it. Don't pull too hard, or you may damage the wires connected to the speaker.
    • After the last tab is removed, tug gently on the outer casing to remove it. Don't pull too hard, or you may damage the wires connected to the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anish Sambamurthy
회원 가입일: 2010년 02월 11일
31 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-21, Maness Winter 2010 Cal Poly, Team 3-21, Maness Winter 2010 회원
CPSU-MANESS-W10S3G21
4 회원들
안내서 10개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 17
전체 시간: 2,543
