주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung SCV-VLUUST50 Flash Bulb Replacement
필요한 것
  1. Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: 1 단계, 이미지 3개 중 1개 Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: 1 단계, 이미지 3개 중 2개 Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: 1 단계, 이미지 3개 중 3개
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Flash Bulb Replacement: 2 단계, 이미지 3개 중 1개 Samsung SCV-VLUUST50 Flash Bulb Replacement: 2 단계, 이미지 3개 중 2개 Samsung SCV-VLUUST50 Flash Bulb Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Flash Bulb Replacement: 3 단계, 이미지 1개 중 1개
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Flash Bulb Replacement: 4 단계, 이미지 2개 중 1개 Samsung SCV-VLUUST50 Flash Bulb Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: 5 단계, 이미지 2개 중 1개 Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: 5 단계, 이미지 2개 중 2개
    • Remove the screw securing the shutter button to the camera frame.
    • Lift the shutter button to remove it.
  6. Samsung SCV-VLUUST50 Flash Bulb Replacement: 6 단계, 이미지 2개 중 1개 Samsung SCV-VLUUST50 Flash Bulb Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the screws from the circuitry with a Phillips #000 driver.
    • Remove the screw connecting the flash housing to the camera frame with the same driver.
  7. Samsung SCV-VLUUST50 Flash Bulb Replacement: 7 단계, 이미지 2개 중 1개 Samsung SCV-VLUUST50 Flash Bulb Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the flash housing away from the camera frame.
    • Cut the wires connecting the flash module to the circuitry.
    • Connect the new flash module to the circuitry with a soldering iron and electrical solder.
결론
작성자
3다른 기여자 명과 함께
Jade Withrow
회원 가입일: 02/08/18
255 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 29
전체 시간: 384
