주요 콘텐츠로 건너뛰기
Samsung SCV-VLUUST50 Screen Replacement
필요한 것
  1. Samsung SCV-VLUUST50 Screen Replacement, Cover: 1 단계, 이미지 1/3 Samsung SCV-VLUUST50 Screen Replacement, Cover: 1 단계, 이미지 2/3 Samsung SCV-VLUUST50 Screen Replacement, Cover: 1 단계, 이미지 3/3
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Screen Replacement: 2 단계, 이미지 1/3 Samsung SCV-VLUUST50 Screen Replacement: 2 단계, 이미지 2/3 Samsung SCV-VLUUST50 Screen Replacement: 2 단계, 이미지 3/3
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Screen Replacement: 3 단계, 이미지 1/1
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Screen Replacement: 4 단계, 이미지 1/2 Samsung SCV-VLUUST50 Screen Replacement: 4 단계, 이미지 2/2
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Screen Replacement, Screen: 5 단계, 이미지 1/3 Samsung SCV-VLUUST50 Screen Replacement, Screen: 5 단계, 이미지 2/3 Samsung SCV-VLUUST50 Screen Replacement, Screen: 5 단계, 이미지 3/3
    • Open the ribbon connector with your fingernail.
    • Pull the ribbon out of the connection.
  6. Samsung SCV-VLUUST50 Screen Replacement: 6 단계, 이미지 1/1
    • Pull the ribbon connected to the screen out from behind the button circuitry on the rear of the camera.
    • Feed the new screen's ribbon through the same slot it came out of.
결론
Evert Jordan
회원 가입일: 02/08/18
287 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 13
전체 시간: 110
