주요 콘텐츠로 건너뛰기
Samsung SCV-VLUUST50 Shutter Button Replacement
필요한 것
  1. Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: 1 단계, 이미지 3개 중 1개 Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: 1 단계, 이미지 3개 중 2개 Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: 1 단계, 이미지 3개 중 3개
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Shutter Button Replacement: 2 단계, 이미지 3개 중 1개 Samsung SCV-VLUUST50 Shutter Button Replacement: 2 단계, 이미지 3개 중 2개 Samsung SCV-VLUUST50 Shutter Button Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Shutter Button Replacement: 3 단계, 이미지 1개 중 1개
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Shutter Button Replacement: 4 단계, 이미지 2개 중 1개 Samsung SCV-VLUUST50 Shutter Button Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: 5 단계, 이미지 3개 중 1개 Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: 5 단계, 이미지 3개 중 2개 Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: 5 단계, 이미지 3개 중 3개
    • Remove the screw below the shutter button with a Phillips #000 screw driver.
    • Once the screw is removed the shutter button should easily come off, and you can replace it with the new button.
결론
작성자
2다른 기여자 명과 함께
Jaeda Ransom
회원 가입일: 02/13/18
123 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 304
