주요 콘텐츠로 건너뛰기
Samsung SGH A707 Motherboard Replacement
필요한 것
  1. Samsung SGH A707 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Press on the markings on the cover and pull it down to reveal the battery.
  2. Samsung SGH A707 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
  3. Samsung SGH A707 Motherboard Replacement: 3 단계, 이미지 1/1
    • Here is the phone without the battery.
  4. Samsung SGH A707 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 Samsung SGH A707 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
  5. Samsung SGH A707 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use the prying tool the pry off the phone's plastic frame.
  6. Samsung SGH A707 Motherboard Replacement: 6 단계, 이미지 1/3 Samsung SGH A707 Motherboard Replacement: 6 단계, 이미지 2/3 Samsung SGH A707 Motherboard Replacement: 6 단계, 이미지 3/3
    • Use the prying tool to disconnect the rectangular connector.
  7. Samsung SGH A707 Motherboard Replacement: 7 단계, 이미지 1/1
    • Use the prying tool to disconnect the small connector.
  8. Samsung SGH A707 Motherboard Replacement: 8 단계, 이미지 1/1
    • Gently pull off the circuit board.
  9. Samsung SGH A707 Motherboard Replacement: 9 단계, 이미지 1/1
    • Here is the phone without the logic board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
yfm
회원 가입일: 11/06/12
25 평판
안내서 7개 작성하였습니다
University of Maryland, Team 1-1, Calloway Fall 2012 University of Maryland, Team 1-1, Calloway Fall 2012 회원
UMD-CALLOWAY-F12S1G1
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 11
전체 시간: 727
