주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Samsung SGH-A117 수리는 저희 서비스 설명서를 사용하십시오.
  1. Samsung SGH-A117: Breakdown and Reassembly, Samsumg SGH-A117: 1 단계, 이미지 1/1
    • This is the Samsung SGH-A117.
  2. Samsung SGH-A117: Breakdown and Reassembly, Backside of the cellphone: 2 단계, 이미지 1/1
    • This is the back view following the removal of the back cover and battery.
  3. Samsung SGH-A117: Breakdown and Reassembly, Removing Screws: 3 단계, 이미지 1/1
    • Use a screwdriver to remove screws around the frame.
    • Use a PH00 size screw to operate this step.
    • The screws are extremely small. It is recommended to have a small container to keep track of the screws.
  4. Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: 4 단계, 이미지 1/2 Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: 4 단계, 이미지 2/2
    • Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
    • The end of the phone closest to the hinge will require additional force to lift.
    • Be careful not to bend the cover during the removal process.
  5. Samsung SGH-A117: Breakdown and Reassembly, Separate Circuit Connector from Logic Board: 5 단계, 이미지 1/1
    • Use a spudger to gently lift the circuit connector from the logic board.
    • Be careful not to remove the circuit connector from the phone.
  6. Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: 6 단계, 이미지 1/2 Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: 6 단계, 이미지 2/2
    • Use a spudger to lift the logic board and separate it from the main body of the phone.
    • It is recommended to lift from the bottom part of the logic board as shown in the picture.
    • Be careful not to lose the volume button, which is loosely attached to the logic board.
  7. Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: 7 단계, 이미지 1/2 Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: 7 단계, 이미지 2/2
    • Gently push the keyboard from the case as shown in the picture.
  8. Samsung SGH-A117: Breakdown and Reassembly, Layout of Disassembled Device: 8 단계, 이미지 1/1
    • 1 Case
    • 1 Keyboard
    • 1 Logic Board
    • 1 Volume Control
    • 1 Back Cover
    • 5 Screws
Justin
회원 가입일: 10/06/14
150 평판
안내서 2개 작성하였습니다
Aristotle Aristotle 회원
Community
5 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 820
