소개
This repair guide shows how to replace the back cover on the Samsung SGH-237 cellphone.
부품
부품은 필요하지 않습니다.
  1. Put the phone face down so that the battery cover is showing. Put the phone face down so that the battery cover is showing.
    • Put the phone face down so that the battery cover is showing.
  2. Use your thumb to push the battery cover off. Lift the battery off the device.
    • Use your thumb to push the battery cover off.
    • Lift the battery off the device.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown. Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  5. Carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device. Note: some force must be applied to remove back cover. Note: some force must be applied to remove back cover.
    • Carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Note: some force must be applied to remove back cover.
결론
Theodore Johansen
회원 가입일: 2010년 04월 14일
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 29-81, Johann Spring 2010 Cal Poly, Team 29-81, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G81
4 회원들
안내서 8개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,327
