주요 콘텐츠로 건너뛰기
Samsung SGH-A237 Camera Replacement
필요한 것
  1. Samsung SGH-A237 Camera Replacement, Camera: 1 단계, 이미지 1/1
    • Place the phone on a flat surface with the camera facing upwards.
    • Have a designated space to keep track of each small part.
  2. Samsung SGH-A237 Camera Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Open the phone.
    • Remove the two rubber soft screw covers below the viewing screen using a pair of tweezers.
  3. Samsung SGH-A237 Camera Replacement: 3 단계, 이미지 1/1
    • Loosen the screws under the soft screw covers using a Phillips #00 screwdriver.
  4. Samsung SGH-A237 Camera Replacement: 4 단계, 이미지 1/3 Samsung SGH-A237 Camera Replacement: 4 단계, 이미지 2/3 Samsung SGH-A237 Camera Replacement: 4 단계, 이미지 3/3
    • Failure to utilize the specified tool may cause damage to the device.
    • Locate the black cover plate on the back side of the viewing screen. It will show the AT&T and Samsung logos.
    • Look on the right side of the phone for the crease in between the black back cover and the front silver cover of the viewing screen.
    • Pry the cover plate off using a plastic opening tool.
  5. Samsung SGH-A237 Camera Replacement: 5 단계, 이미지 1/2 Samsung SGH-A237 Camera Replacement: 5 단계, 이미지 2/2
    • Identify the metal bracket that covers the internal body.
    • Identify the metal tabs surrounding the metal bracket mentioned in the previous step.
    • Remove the metal bracket using a small pick or a Phillips #00 screwdriver.
    • Close the phone.
  6. Samsung SGH-A237 Camera Replacement: 6 단계, 이미지 1/1
    • Find the camera on the upper part of the phone. It will be displayed as a small black circle.
    • Follow the copper ribbon connected to the camera downward to the black connection port.
  7. Samsung SGH-A237 Camera Replacement: 7 단계, 이미지 1/2 Samsung SGH-A237 Camera Replacement: 7 단계, 이미지 2/2
    • Failure to utilize the specified tool in the proper way may cause damage to the device.
    • Pry up the black connector using a pick. This should lock the black connector into an upward position, which will release the copper ribbon connected to the phone's camera.
  8. Samsung SGH-A237 Camera Replacement: 8 단계, 이미지 1/2 Samsung SGH-A237 Camera Replacement: 8 단계, 이미지 2/2
    • Gently grasp the copper ribbon attached to the camera using a pair of tweezers.
    • Gently pull copper ribbon towards the camera. This should pull the copper ribbon out completely.
  9. Samsung SGH-A237 Camera Replacement: 9 단계, 이미지 1/1
    • Remove the camera.
결론
Jonathon
회원 가입일: 10/15/14
10 평판
안내서 1개 작성함
Ohio State, Team 1-4, Mccook Fall 2014 Ohio State, Team 1-4, Mccook Fall 2014 회원
OSU-MCCOOK-F14S1G4
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 360
