주요 콘텐츠로 건너뛰기
Samsung SGH-A237 Logic Board Replacement
필요한 것
  1. Samsung SGH-A237 Logic Board Replacement, Logic Board: 1 단계, 이미지 1/2 Samsung SGH-A237 Logic Board Replacement, Logic Board: 1 단계, 이미지 2/2
    • Put the phone face down so that the battery cover is showing.
  2. Samsung SGH-A237 Logic Board Replacement: 2 단계, 이미지 1/2 Samsung SGH-A237 Logic Board Replacement: 2 단계, 이미지 2/2
    • Use your thumb to push the cover down and off.
    • Lift the battery off the device.
  3. Samsung SGH-A237 Logic Board Replacement: 3 단계, 이미지 1/2 Samsung SGH-A237 Logic Board Replacement: 3 단계, 이미지 2/2
    • Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Logic Board Replacement: 4 단계, 이미지 1/3 Samsung SGH-A237 Logic Board Replacement: 4 단계, 이미지 2/3 Samsung SGH-A237 Logic Board Replacement: 4 단계, 이미지 3/3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Note: some force must be applied when removing back cover.
  5. Samsung SGH-A237 Logic Board Replacement: 5 단계, 이미지 1/1
    • Detach the tab from the logic board by using iPod Opening Tool (as shown).
  6. Samsung SGH-A237 Logic Board Replacement: 6 단계, 이미지 1/2 Samsung SGH-A237 Logic Board Replacement: 6 단계, 이미지 2/2
    • Use iPod Opening Tool to lift the green logic board carefully.
    • Remove logic board from the device and replace with new one.
결론
Theodore Johansen
회원 가입일: 04/14/10
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 29-81, Johann Spring 2010 Cal Poly, Team 29-81, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G81
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 2,805
