주요 콘텐츠로 건너뛰기
Samsung SGH-E317 Camera Replacement
필요한 것
  1. Samsung SGH-E317 Camera Replacement, Camera: 1 단계, 이미지 1/2 Samsung SGH-E317 Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Remove the plastic coverings at the base of the LCD screen using your fingers.
  2. Samsung SGH-E317 Camera Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the screwdriver to remove the two 4.5mm screws located underneath the plastic coverings.
    • You may want to use tweezers to remove the loosened screws.
  3. Samsung SGH-E317 Camera Replacement: 3 단계, 이미지 1/1
    • Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
    • Gently pry the top panel off around the entire frame.
  4. Samsung SGH-E317 Camera Replacement: 4 단계, 이미지 1/2 Samsung SGH-E317 Camera Replacement: 4 단계, 이미지 2/2
    • Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
  5. Samsung SGH-E317 Camera Replacement: 5 단계, 이미지 1/1
    • Take the top panel off of the phone.
  6. Samsung SGH-E317 Camera Replacement: 6 단계, 이미지 1/2 Samsung SGH-E317 Camera Replacement: 6 단계, 이미지 2/2
    • Use the wedge to detach the connecting wire panel from the LCD display system.
    • Be gentle when dethatching this wire to prevent damaging surrounding components.
  7. Samsung SGH-E317 Camera Replacement: 7 단계, 이미지 1/2 Samsung SGH-E317 Camera Replacement: 7 단계, 이미지 2/2
    • Use the tweezers to remove the camera from the cellphone casing.
결론
Michael Strange
회원 가입일: 01/30/11
101 평판
안내서 1개 작성함
Cal Poly, Team 11-23, Maness Winter 2011 Cal Poly, Team 11-23, Maness Winter 2011 회원
CPSU-MANESS-W11S11G23
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 1,517
