주요 콘텐츠로 건너뛰기
Samsung SGH-E317 Motherboard Replacement
필요한 것
  1. Samsung SGH-E317 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. Samsung SGH-E317 Motherboard Replacement, Motherboard: 2 단계, 이미지 1/1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. Samsung SGH-E317 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the rubber screw cover using your fingernail.
  4. Samsung SGH-E317 Motherboard Replacement: 4 단계, 이미지 1/1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. Samsung SGH-E317 Motherboard Replacement: 5 단계, 이미지 1/1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. Samsung SGH-E317 Motherboard Replacement: 6 단계, 이미지 1/1
    • With the back panel removed, the motherboard should be fully exposed.
  7. Samsung SGH-E317 Motherboard Replacement: 7 단계, 이미지 1/2 Samsung SGH-E317 Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. Samsung SGH-E317 Motherboard Replacement: 8 단계, 이미지 1/2 Samsung SGH-E317 Motherboard Replacement: 8 단계, 이미지 2/2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. Samsung SGH-E317 Motherboard Replacement: 9 단계, 이미지 1/2 Samsung SGH-E317 Motherboard Replacement: 9 단계, 이미지 2/2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
결론
Chris Dimler
회원 가입일: 01/22/11
124 평판
안내서 1개 작성함
Cal Poly, Team 11-23, Maness Winter 2011 Cal Poly, Team 11-23, Maness Winter 2011 회원
CPSU-MANESS-W11S11G23
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,382
