주요 콘텐츠로 건너뛰기
Samsung SGH-T639 Keypad Replacement
필요한 것
  1. Samsung SGH-T639 Keypad Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. Samsung SGH-T639 Keypad Replacement: 2 단계, 이미지 1/1
    • Use button to remove battery from the phone.
  3. Samsung SGH-T639 Keypad Replacement, SIM Card: 3 단계, 이미지 1/3 Samsung SGH-T639 Keypad Replacement, SIM Card: 3 단계, 이미지 2/3 Samsung SGH-T639 Keypad Replacement, SIM Card: 3 단계, 이미지 3/3
    • Locate SIM card
    • Slide SIM card down and gently pull out of the card slot
  4. Samsung SGH-T639 Keypad Replacement, Motherboard: 4 단계, 이미지 1/3 Samsung SGH-T639 Keypad Replacement, Motherboard: 4 단계, 이미지 2/3 Samsung SGH-T639 Keypad Replacement, Motherboard: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Locate the six (4mm) screws on the back casing of the phone.
    • Unscrew each one using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  5. Samsung SGH-T639 Keypad Replacement: 5 단계, 이미지 1/3 Samsung SGH-T639 Keypad Replacement: 5 단계, 이미지 2/3 Samsung SGH-T639 Keypad Replacement: 5 단계, 이미지 3/3
    • Starting at the top of the phone, carefully insert plastic opening device into the seam.
    • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
    • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
    • Note: The volume button may separate from the case, this is normal. It is not broken.
  6. Samsung SGH-T639 Keypad Replacement: 6 단계, 이미지 1/3 Samsung SGH-T639 Keypad Replacement: 6 단계, 이미지 2/3 Samsung SGH-T639 Keypad Replacement: 6 단계, 이미지 3/3
    • Locate the connection point of black wire running from the microphone to the motherboard.
    • Carefully disconnect the gold connector from the motherboard using tweezers.
  7. Samsung SGH-T639 Keypad Replacement: 7 단계, 이미지 1/3 Samsung SGH-T639 Keypad Replacement: 7 단계, 이미지 2/3 Samsung SGH-T639 Keypad Replacement: 7 단계, 이미지 3/3
    • Locate the red connector at the top of the motherboard.
    • Carefully lift and remove the connector from the motherboard using tweezers.
  8. Samsung SGH-T639 Keypad Replacement: 8 단계, 이미지 1/3 Samsung SGH-T639 Keypad Replacement: 8 단계, 이미지 2/3 Samsung SGH-T639 Keypad Replacement: 8 단계, 이미지 3/3
    • Locate the gold connector that connects the screen to the motherboard.
    • Carefully disconnect the connector from the motherboard using tweezers.
  9. Samsung SGH-T639 Keypad Replacement: 9 단계, 이미지 1/3 Samsung SGH-T639 Keypad Replacement: 9 단계, 이미지 2/3 Samsung SGH-T639 Keypad Replacement: 9 단계, 이미지 3/3
    • Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
    • Lift the motherboard from the cell phone.
  10. Samsung SGH-T639 Keypad Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard from the cell phone.
  11. Samsung SGH-T639 Keypad Replacement, Keypad: 11 단계, 이미지 1/2 Samsung SGH-T639 Keypad Replacement, Keypad: 11 단계, 이미지 2/2
    • Locate the two black, rubber tabs near the top of the back of the phone.
    • Locate the one black, rubber tab near the base of the phone.
  12. Samsung SGH-T639 Keypad Replacement: 12 단계, 이미지 1/3 Samsung SGH-T639 Keypad Replacement: 12 단계, 이미지 2/3 Samsung SGH-T639 Keypad Replacement: 12 단계, 이미지 3/3
    • Using tweezers, pry each of the tabs open.
    • Tuck each tab behind the white notch.
    • By tucking the tabs behind each notch. This allows improves the ease of removing the keypad.
  13. Samsung SGH-T639 Keypad Replacement: 13 단계, 이미지 1/3 Samsung SGH-T639 Keypad Replacement: 13 단계, 이미지 2/3 Samsung SGH-T639 Keypad Replacement: 13 단계, 이미지 3/3
    • Flip phone over to make the keypad visable.
    • Carefully lift keypad around the edges.
    • Remove keypad from the cell phone.
결론
Yi Ren
회원 가입일: 03/26/14
801 평판
안내서 8개 작성하였습니다
Clemson, Team 1-4, Benson Spring 2014 Clemson, Team 1-4, Benson Spring 2014 회원
CLEM-BENSON-S14S1G4
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 294
