주요 콘텐츠로 건너뛰기
Samsung SGH-T639 Screen Replacement
필요한 것
  1. Samsung SGH-T639 Screen Replacement, Screen: 1 단계, 이미지 1/3 Samsung SGH-T639 Screen Replacement, Screen: 1 단계, 이미지 2/3 Samsung SGH-T639 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Flip phone over and locate the screw covers.
    • Remove the two thin screw covers using the tweezers.
  2. Samsung SGH-T639 Screen Replacement: 2 단계, 이미지 1/3 Samsung SGH-T639 Screen Replacement: 2 단계, 이미지 2/3 Samsung SGH-T639 Screen Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Locate the two screws (3mm) at the base of the top portion of the cell phone.
    • Remove screws using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  3. Samsung SGH-T639 Screen Replacement: 3 단계, 이미지 1/2 Samsung SGH-T639 Screen Replacement: 3 단계, 이미지 2/2
    • Locate the seam of the casing along the edge of the phone.
    • Starting at the end, gently begin to pry the front casing away from the phone. Use the plastic opening tool for this step.
  4. Samsung SGH-T639 Screen Replacement: 4 단계, 이미지 1/3 Samsung SGH-T639 Screen Replacement: 4 단계, 이미지 2/3 Samsung SGH-T639 Screen Replacement: 4 단계, 이미지 3/3
    • Continue to pry the casing from the front of the cell phone.
    • Remove front casing from the cell phone.
  5. Samsung SGH-T639 Screen Replacement: 5 단계, 이미지 1/3 Samsung SGH-T639 Screen Replacement: 5 단계, 이미지 2/3 Samsung SGH-T639 Screen Replacement: 5 단계, 이미지 3/3
    • Locate the small battery at the end of the cell phone.
    • Gently remove the battery from the cell phone using tweezers.
    • Note: This may require some force.
    • Do not disconnect the battery from the entire phone. Simply lift the battery from the cell phone while keeping the wires connected.
  6. Samsung SGH-T639 Screen Replacement: 6 단계, 이미지 1/3 Samsung SGH-T639 Screen Replacement: 6 단계, 이미지 2/3 Samsung SGH-T639 Screen Replacement: 6 단계, 이미지 3/3
    • Locate the speaker at the end of the cell phone.
    • Gently grasp and lift the speaker from the cell phone using tweezers.
    • Do not disconnect the speaker from the entire cell phone. Simply lift the speaker while leaving the wires connected.
  7. Samsung SGH-T639 Screen Replacement: 7 단계, 이미지 1/3 Samsung SGH-T639 Screen Replacement: 7 단계, 이미지 2/3 Samsung SGH-T639 Screen Replacement: 7 단계, 이미지 3/3
    • Locate the tip of the sheer protection film.
    • Gently lift and remove the protection film with tweezers.
  8. Samsung SGH-T639 Screen Replacement: 8 단계, 이미지 1/3 Samsung SGH-T639 Screen Replacement: 8 단계, 이미지 2/3 Samsung SGH-T639 Screen Replacement: 8 단계, 이미지 3/3
    • Locate the top tabs of the screen and circuit board unit
    • Gently lift the screen and circuit board as one unit from the cell phone using the tweezers.
    • Make sure the screen and circuit board are removed as one unit. Do not disconnect the screen from the circuit board.
  9. Samsung SGH-T639 Screen Replacement: 9 단계, 이미지 1/3 Samsung SGH-T639 Screen Replacement: 9 단계, 이미지 2/3 Samsung SGH-T639 Screen Replacement: 9 단계, 이미지 3/3
    • Locate the gold connector that is attached to the circuit board.
    • Pull the connection away from the circuit board.
  10. Samsung SGH-T639 Screen Replacement: 10 단계, 이미지 1/1
    • Completely remove the screen and circuit board unit from the cell phone.
결론
Yi Ren
회원 가입일: 03/26/14
801 평판
안내서 8개 작성하였습니다
Clemson, Team 1-4, Benson Spring 2014 Clemson, Team 1-4, Benson Spring 2014 회원
CLEM-BENSON-S14S1G4
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 361
