주요 콘텐츠로 건너뛰기
Samsung SGH-T639 Volumn Button Replacement
필요한 것
  1. Samsung SGH-T639 Volumn Button Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. Samsung SGH-T639 Volumn Button Replacement: 2 단계, 이미지 1/1
    • Use button to remove battery from the phone.
  3. Samsung SGH-T639 Volumn Button Replacement, SIM Card: 3 단계, 이미지 1/3 Samsung SGH-T639 Volumn Button Replacement, SIM Card: 3 단계, 이미지 2/3 Samsung SGH-T639 Volumn Button Replacement, SIM Card: 3 단계, 이미지 3/3
    • Locate SIM card
    • Slide SIM card down and gently pull out of the card slot
  4. Samsung SGH-T639 Volumn Button Replacement, Volumn Button: 4 단계, 이미지 1/3 Samsung SGH-T639 Volumn Button Replacement, Volumn Button: 4 단계, 이미지 2/3 Samsung SGH-T639 Volumn Button Replacement, Volumn Button: 4 단계, 이미지 3/3
    • Locate the six (4mm) screws on the back of the phone.
    • Unscrew all six screws using a Phillips head #000 screwdriver.
  5. Samsung SGH-T639 Volumn Button Replacement: 5 단계, 이미지 1/3 Samsung SGH-T639 Volumn Button Replacement: 5 단계, 이미지 2/3 Samsung SGH-T639 Volumn Button Replacement: 5 단계, 이미지 3/3
    • Locate volume button.
    • Starting at the top, pry the back casing of the phone.
    • Continue prying around the side of the phone. Being careful around the volume button.
  6. Samsung SGH-T639 Volumn Button Replacement: 6 단계, 이미지 1/3 Samsung SGH-T639 Volumn Button Replacement: 6 단계, 이미지 2/3 Samsung SGH-T639 Volumn Button Replacement: 6 단계, 이미지 3/3
    • Remove back casing from the phone.
    • Relocate the volume button.
    • Gently push the volume button towards the interior of the back casing of the phone.
  7. Samsung SGH-T639 Volumn Button Replacement: 7 단계, 이미지 1/1
    • Completely remove the volume button from the cell phone.
결론
Yi Ren
회원 가입일: 03/26/14
801 평판
안내서 8개 작성하였습니다
Clemson, Team 1-4, Benson Spring 2014 Clemson, Team 1-4, Benson Spring 2014 회원
CLEM-BENSON-S14S1G4
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 163
