주요 콘텐츠로 건너뛰기
Samsung SGH-X495 Headphone Jack Replacement
필요한 것
  1. Samsung SGH-X495 Headphone Jack Replacement, Backplate: 1 단계, 이미지 1/1
    • Remove the 4 (4.7mm) philips head screws.
  2. Samsung SGH-X495 Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Unplug the rubber charger outlet cover.
  3. Samsung SGH-X495 Headphone Jack Replacement: 3 단계, 이미지 1/1
    • Unplug the rubber headset jack cover.
  4. Samsung SGH-X495 Headphone Jack Replacement: 4 단계, 이미지 1/2 Samsung SGH-X495 Headphone Jack Replacement: 4 단계, 이미지 2/2
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  5. Samsung SGH-X495 Headphone Jack Replacement: 5 단계, 이미지 1/2 Samsung SGH-X495 Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
  6. Samsung SGH-X495 Headphone Jack Replacement, Motherboard: 6 단계, 이미지 1/1
    • Remove the ribbon wires connecting to the screen using the pry tool.
  7. Samsung SGH-X495 Headphone Jack Replacement: 7 단계, 이미지 1/1
    • 2 tabs hold the motherboard in place.
    • Release the labeled tabs with the pry tool from the location shown.
  8. Samsung SGH-X495 Headphone Jack Replacement: 8 단계, 이미지 1/1
    • Separate the motherboard from the phone.
  9. Samsung SGH-X495 Headphone Jack Replacement, Headphone Jack: 9 단계, 이미지 1/1
    • Solder connections can be accessed to replace head phone jack.
결론
Matthew Hove
회원 가입일: 01/05/11
1,031 평판
안내서 10개 작성하였습니다
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011 회원
CPSU-REGAN-W11S3G40
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,726
