주요 콘텐츠로 건너뛰기
Samsung SGH-X495 Speakers Replacement
필요한 것
  1. Samsung SGH-X495 Speakers Replacement, Face Plate: 1 단계, 이미지 1/1
    • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
  2. Samsung SGH-X495 Speakers Replacement: 2 단계, 이미지 1/1
    • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
  3. Samsung SGH-X495 Speakers Replacement: 3 단계, 이미지 1/2 Samsung SGH-X495 Speakers Replacement: 3 단계, 이미지 2/2
    • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
    • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
  4. Samsung SGH-X495 Speakers Replacement: 4 단계, 이미지 1/2 Samsung SGH-X495 Speakers Replacement: 4 단계, 이미지 2/2
    • Continue down each side toward the bottom with your pry tool.
    • Note: It may help to use multiple pry tools to help hold it open.
    • Second photo: location of the tabs.
  5. Samsung SGH-X495 Speakers Replacement: 5 단계, 이미지 1/2 Samsung SGH-X495 Speakers Replacement: 5 단계, 이미지 2/2
    • With 8 tabs released, the face plate is nearly free.
    • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • Note: A strip of double sided tape holds the faceplate, so expect some resistance
  6. Samsung SGH-X495 Speakers Replacement, Speakers: 6 단계, 이미지 1/2 Samsung SGH-X495 Speakers Replacement, Speakers: 6 단계, 이미지 2/2
    • Remove the 2 speakers by gently prying them up.
    • The speakers are attached with double sided tape.
  7. Samsung SGH-X495 Speakers Replacement: 7 단계, 이미지 1/1
    • With the speakers free from the phones body the screen is loose as well.
    • The desired solder joint can be accessed to attach a new speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Hove
회원 가입일: 01/05/11
1,031 평판
안내서 10개 작성하였습니다
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011 회원
CPSU-REGAN-W11S3G40
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,754
